Creating dashboards full of data is only for data centres / mission control / spaceships, right?
Tesserae running on a selection of Pimoroni displays
Kayden D'Mello, a Melbourne, Australia based developer has created the Tesserae project. The project "is an ecosystem for e-ink displays. You design a dashboard in your browser, and Tesserae renders it and sends it to whatever panels you own." according to Kayden.
Inky Impression
Turn your Raspberry Pi into a colourful e-paper picture frame, dashboard or display with Inky Impression.
There is no need for fiddly scripts. You design it once, and the dashboard is sent to whatever screen you want it to appear on. The project supports a plethora of platforms including Inky Impression 7.3 and 13.3 , Inky Frame 7.3, Badger 2350 and Badger 2040 (Retired). Other supported platforms include ESP32, TRMNL, Seeed's reTerminal E-Series, Amazon Kindle and Kobo e-readers. All you need is your own local server (there is a cloud server coming soon) and the correct software on the client device.
Designing the dashboard in the browser
From there you can design your own dashboard using widgets. We have total control on widget placement. Or we can use a grid to slot widgets into their own areas. Via the widgets we can display useful information like calendars, weather and even smart home data using Home Assistant. We installed a Tesserae server on our Home Assistant Green and then spent a little time setting up our Inky Frame 7.3. To test, we set it to show Wikipedia's "On This Day" and the RSS feed for our learning guides.
Our dashboard, created using Tesserae's browser based design tool
A recently added feature is a web flasher tool for our Inky Frame boards. Plug in your Inky Frame, connect to it using Chrome's WebUSB, choose the correct firmware and you'll soon be seeing your dashboards on a low-power display. That is how we got started, and it was a pleasantly simple experience.
The web flasher user interface as we flash Inky Frame 7.3
The Tesserae project has grown into a community. There are now many contributors who are expanding the project with bug reports and new ideas. The Home Assistant integration being a notable addition that stemmed from the community.
Kayden would like to thank Bernhard Bablok (bablokb on GitHub and a regular user of our forums.) They wrote and maintain the CircuitPython client for Tesserae, which is how Inky Frame 5.7" and 4" are supported, along with other CircuitPython boards. Bernhard has been a tremendous help to the Tesserae project, right back to its earliest iterations.
Check out the main Tesserae GitHub repo, and also take a look at Kayden's other projects via their GitHub page.
Please note: All Tesserae work has been supervised by Kayden's cats Ada and Tux.
CTA Image
Got a cool project that you'd like to share? Drop us an email!
Email Les!
